1975 Viper bridge adjustment
Vadim
Posted 2011-06-30 8:23 AM (#350479)
Subject: 1975 Viper bridge adjustment
May 2010
Recently got this black Viper. There is some string buzz on the frets because the action is really low.
Viper had several different variations of bridges. This one has the following:
1) Front
2) Back
How would one go about raising the action on this thing? I don't even know how you could control the angle because the screw for angle is freaky.
Posted 2011-06-30 1:17 PM (#350480 - in reply to #350479)
Subject: Re: 1975 Viper bridge adjustment
That's not the bridge that came with that guitar. The opening in the back says that the original bridge was the brass (or nylon) saddle bridge with the plastic cover.
That particular Schaller bridge was used on late 80's/early 90's guitars.
Isn't the action adjusted with the big screws on either end of the bridge? Counter clock wise to raise, clock wise to lower?
Posted 2011-06-30 1:25 PM (#350481 - in reply to #350479)
yup.. what he said.
Posted 2011-06-30 1:42 PM (#350482 - in reply to #350479)
It is most likely the original bridge, as the guitar is later than 1975. The black finish option was not offered until relatively late in production.
The Schaller bridge adjusts from the 2 mounting bolts. There is no rear bolt, it's just a plug for the hole.
Posted 2011-06-30 2:48 PM (#350483 - in reply to #350479)
The "usually" painted the plug, but I guess the finish could have come off, or they just didn't put finish on it. I've not seen one unfinished, but that doesn't mean anything either. So Templeman might be right on about the color not offered until later in production.
In any case... just use the mounting bolts. If you happen to take the bridge off, there may be some writing under it on the body. Sometimes an model number with the color code, or a date. Not always, but sometimes. Next time you change strings, might be worth a look. The other place to scribble notes is in the pickup cavity. Again, if ya happen to be in the neighborhood, take a look. It will either find some info that will be helpful, useless or blank. :)
Posted 2011-06-30 3:03 PM (#350484 - in reply to #350479)
I've never seen a Viper with an original Schaller bridge that had the hole thru the body, but as Temp has pointed out in the past, "just when you think you've seen it all". It's all of us taking our best guesses......
Posted 2011-06-30 4:50 PM (#350485 - in reply to #350479)
If true it was from the last batches as they emptied the bins.
Nice one.
Posted 2011-06-30 5:19 PM (#350486 - in reply to #350479)
Moody, Every Viper I've seen with a Schaller bridge, which is several dozen at least, had the hole through the back.
Posted 2011-07-01 4:05 AM (#350487 - in reply to #350479)
There is no hole in my Viper with the late Schaller bridge. Mine's very late in the run with a mahogany neck and body.
kitmann
Posted 2011-07-01 5:34 AM (#350488 - in reply to #350479)
April 2010
That looks like the same bridge on my Viper, in the back of the bridge it just says Ovation with no hole on mine, does that mean it's an original bridge?
kitmann
Posted 2011-07-01 5:36 AM (#350489 - in reply to #350479)
April 2010
Can't edit. No hole in the back of the guitar is what I meant.
Posted 2011-07-01 2:17 PM (#350490 - in reply to #350479)
Hmm that's interesting. I wonder if it was a geography thing. Of the ones with Schaller's, I have only seen a few with the hole filled and it's always been finished over. Always something interesting...
Posted 2011-07-01 4:46 PM (#350491 - in reply to #350479)
"I wonder if it was a geography thing"
I guess the spare part units went to EU and the better batch went to CA.
Most of mine came from separate boxes or bins anyway.
Posted 2011-07-01 7:07 PM (#350492 - in reply to #350479)
I've had all of the above. Old bridge with bolt thru the body, new bridge with plugged hole (unfinished only on a barn burst) and no hole on the one I currently own
Posted 2011-07-01 8:26 PM (#350493 - in reply to #350479)
If you can think of it, Ovation's done it (not talking porn here).......
