Neck Bow Only At High End?
martinez
Posted 2011-12-06 11:53 AM (#346090)
Subject: Neck Bow Only At High End?
September 2011
Is this possible? If I put a straight edge on my Takamine neck, it touches all the way up, dead straight, when I put it on my Elite, there is a gap from fret 12 to 16...so that means it's bowed , right?
I thought bowed necks were usually bowed in the middle, showing gaps under frets 5 up to about 8 or 9, wouldn't that be more normal?
Cheers
Craig
CanterburyStrings
Posted 2011-12-06 12:19 PM (#346091 - in reply to #346090)
Subject: Re: Neck Bow Only At High End?
March 2008
What you're seeing is the infamous "14th fret drop off". Lots of guitars have this, not just Ovations. If it causes a buzz, it needs to be taken care of. If not, don't worry about it.
Posted 2011-12-06 12:33 PM (#346092 - in reply to #346090)
what she said
she knows
she was an inspector
martinez
Posted 2011-12-06 12:36 PM (#346093 - in reply to #346090)
September 2011
But it's making the action way too high...I can't ignore it, it's annoying. :-)
I want it to play easier (if possible) than my Tak, otherwise it aint gonna get used at all :-(
jay
Posted 2011-12-06 12:51 PM (#346094 - in reply to #346090)
January 2009
Not to hijack the thread, (and maybe I am the only one that doesn't know...not unusual) but I am curious as to what one would have to do to have the infamous "14th fret drop off" corrected.
Darkbar
Posted 2011-12-06 12:56 PM (#346095 - in reply to #346090)
January 2009
Eliminate the "drop off"
CanterburyStrings
Posted 2011-12-06 7:52 PM (#346096 - in reply to #346090)
March 2008
Humidify. SLOWLY. When it gets too dry, the top will sink some, and take the end of the fretboard with it. If, after humidifying, the drop off is still bad, you would either need a neck re-set, or if you don't play that far up the neck, you could file the problem frets down.
