Case needed for a 12 string Deacon
Posted 2004-01-05 3:30 PM (#342002)
Subject: Case needed for a 12 string Deacon
I know this is a tough one but I am looking for a OEM case for my 12 string Deacon if anyone has one please contact me at peacebdog@hotmail.com
Bluebird
Posted 2004-01-05 5:25 PM (#342003 - in reply to #342002)
Subject: Re: Case needed for a 12 string Deacon
I know with the Preacher/Viper type cases, there is only one model case and it will fit both 12 and 6 string guitars. I assume that is probably true for the Deacon/Breadwinner cases as well. They turn up occasionally on Ebay and perhaps someone here has one for sale.
Wayne
samova
Posted 2004-01-05 8:17 PM (#342004 - in reply to #342002)
That is not the case with the deacon/breadwinner cases.Before the 12 string deacon was introduced the cases were about 1 inch shorter and fit the six string models perfectly.They would not fit the later 12 string models.After the 12 string was introduced the new cases were slightly longer and would fit both 12 and 6 string models..So, if you have a case with the brown square feet atached on the bottom,they will not fit a 12 string.The later cases had the ball bearing feet..Those are the ones that fit the 12 strings...
