Slip-Grip "anti-slip" patch for Ovation guitars
Slip-Grip
Posted 2006-06-21 6:44 PM (#327109)
Subject: Slip-Grip "anti-slip" patch for Ovation guitars
March 2006
Round-back guitars are notorious for slipping on your leg due to the shape and texture of their fiberglass bowl. Finally ... there is a solution that really works !
Slip-Grip is a self-adhesive, "anti-slip" patch that eliminates the frustrating slipping motion of round-back guitars when they are played while sitting down.
If you would like more information regarding Slip-Grip, please contact me at: Slip-Grip@verizon.net
Jim
Posted 2006-06-21 6:51 PM (#327110 - in reply to #327109)
Subject: Re: Slip-Grip "anti-slip" patch for Ovation guitars
The Slip-Grip folks were kind enough to send out some samples and ask for opinions several months back. If slippage is a problem for you, give these a try.
Jim, I remember several of us mentioned the "glue" issue. Was this ever addressed?
noah
Posted 2006-06-22 2:49 AM (#327111 - in reply to #327109)
Welcome back Jim,
Were you ever able to address the adhesion issue of the patch to the bowl?
After cleaning the bowl area with an alcohol wipe and geting the paper backing off the patch, it applied easily to the bowl.
The "anti-slip" surface worked, but I found the Slip-Grip Patch only partially attached to the bowl the next morning.
hosebei
Posted 2006-06-22 5:00 AM (#327112 - in reply to #327109)
June 2004
I am one of the slipgripfolkloseroftheslipgripaftertwodays.....but the hint with the hairspray was perfect.
My slip-grips (3) are sitting tight now.
All I can say is, that it works perfectly for me now. If you have the problem of losing your guitar all the time (where the hell is my legend???) give it a try and your baby will stay on your knees...
noah
Posted 2006-06-22 6:07 AM (#327113 - in reply to #327109)
Originally posted by hosebei:
...but the hint with the hairspray was perfect. My slip-grips (3) are sitting tight now.
I must have been cutting class the day hairspray was discussed. Can I borrow someone's notes?
Posted 2006-06-22 7:13 AM (#327114 - in reply to #327109)
Me too. No matter what I tried, the thing was either on the floor or headed that way the next morning.
I'd be interested in knowing what might make them stay put.
Posted 2006-06-22 10:21 AM (#327115 - in reply to #327109)
I still don't get the whole "Slippage" thing in the first place.
Posted 2006-06-22 10:34 AM (#327116 - in reply to #327109)
Mine have never slipped either but it appears to be a common problem. I think it is the angle at which some people hold/place their guitars on their laps....or maybe they started out with box guitars vs ovations and developed bad habits.
I never heard about the "hair spray" solution either.
Posted 2006-06-22 10:41 AM (#327117 - in reply to #327109)
Mine falls off overnight when the guitar is hanging on the wall.
Posted 2006-06-22 10:41 AM (#327118 - in reply to #327109)
Hairspray has a number of uses like this. I put new handlebar grips on my bicycles using hairspray. You spray it on and as a liquid it acts as a lubricant so you can slide the grip easily on the handlebar. Then it dries just like a glue and holds the grip firmly in place.
I've never had any troubles with slipping either, but that does not mean the problem does not exist for others. 3M bathtub anti-slip tape also works well.
Steve
Posted 2006-06-22 11:05 AM (#327119 - in reply to #327109)
July 2002
Mine adheres fairly well on my '92 1767, but at times it tends to curl up a little on the edges..
ChatMan
Posted 2006-06-22 11:18 AM (#327120 - in reply to #327109)
August 2004
And the floral accent motif really adds to your stage presence as well.
Posted 2006-06-22 11:46 AM (#327121 - in reply to #327109)
The gay rubber non-slip daisies are made by Rubbermaid . . not 3M.
(At least, that's what Witko tells me . . . .)
ChatMan
Posted 2006-06-22 12:41 PM (#327122 - in reply to #327109)
August 2004
Who better to know the supplier of latex products. I just didn't realize his interests extended beyond latex haberdashers.
I stand corrected. A nice segue back towards the Guitarminitrix topic :rolleyes:
Posted 2006-06-22 12:52 PM (#327123 - in reply to #327109)
Rubbermaid makes a wide variety of non-skip tape and decal designs, such as fish, mermaids, kitties, etc. However they do not make daisies. You have to get the daisies from a company called FunMats.
3M makes anti-skid tape which is 3/4 inch wide and 17 inch long. Just cut it to size and stick it on.
Rumor has it that my former "life partner" Standingovation is also working on a line of anti-skid products which should hit the market soon. We can only hope his defination of a anti-skid is the same as ours.
Posted 2006-06-22 12:52 PM (#327124 - in reply to #327109)
Hey, those "gay" daisies were mandatory on our VW Busses in the 60s and 70s. I took them off in the 80s.
Posted 2006-06-22 1:01 PM (#327125 - in reply to #327109)
Being as "GraphicallyAstute" with a brush as I was(am), I didn't go the route of festooning my VW with pre-packaged, die-cut, corporate bathroom accessories . . .
. . . seemed a bit too "Establishment" at the time . . .
Posted 2006-06-22 1:04 PM (#327126 - in reply to #327109)
Too late.
Oh, wait... anti-skid or anti-skidmark?
Phil Wong
Posted 2006-06-22 2:15 PM (#327127 - in reply to #327109)
Careful Waskel,
Can you hear Al's Moderator Siren in the distance?
aaa--aaar-- aaarr-aaarrg-aaarrggg--AAA-AAAR--AAARR-AAARRGGG!!!!!!,aaa--aaar-- aaarr-aaarrg-aaarrggg--AAA-AAAR--AAARR-AAARRGGG!!!!!!,aaa--aaa--aaar-- aaarr-aaarrg-aaarrggg--AAA-AAAR--AAARR-AAARRGGG!!!!!!aaar-- aaarr-aaarrg-aaarrggg--AAA-AAAR--AAARR-AAARRGGG!!!!!!
Posted 2006-06-22 2:25 PM (#327128 - in reply to #327109)
Phil,
Depends...
Phil Wong
Posted 2006-06-22 2:28 PM (#327129 - in reply to #327109)
MWoody,
Velcro or Pull Ups?
BrianT
Posted 2006-06-22 3:17 PM (#327130 - in reply to #327109)
January 2004
I still say the best solution is to glue a big hairy pad to the back of the bowl and then wear a velcro shirt. You wouldnt even need a strap.
Posted 2006-06-22 3:51 PM (#327131 - in reply to #327109)
Just stop leaning on your guitar!!!
Also available for those that have the leaning disability:
Wood Arm Pad
Unnecessary but strangely exotic accessories!
Posted 2006-06-22 3:58 PM (#327132 - in reply to #327109)
Looks kinda cute on that blue CS-257!
Posted 2006-06-22 4:07 PM (#327133 - in reply to #327109)
It does. I like the zebra wood.
Posted 2006-06-22 9:07 PM (#327134 - in reply to #327109)
That is sharp.
Bluebird
Posted 2006-06-23 8:10 AM (#327135 - in reply to #327109)
Hmmm...sharp if you want your O to look like a... BANJO! ;)
Wayne
Posted 2006-06-23 8:33 AM (#327136 - in reply to #327109)
no need to get nasty, Wayne.
If you look close, it appears the dude who snapped the photo is wearing a "puffy shirt."
Posted 2006-06-23 8:57 AM (#327137 - in reply to #327109)
". . but, I don't WANNA be a Pirate!! . . ."
I'm w/Wayne.
I don't see a "point" in it . . . & it looks dumb . . .
Posted 2006-06-23 9:54 AM (#327138 - in reply to #327109)
I disagree - It'll keep my armpit grease off of the guitars finish.
Posted 2006-06-23 10:48 AM (#327139 - in reply to #327109)
i'll take five.
