Wanted-Breadwinner PU selector toggle
Squarepeg
Posted 2008-12-31 8:17 PM (#296342)
Subject: Wanted-Breadwinner PU selector toggle
December 2008
Anyone know where I can get a replacement PU selector toggle for a Breadwinner?
Posted 2008-12-31 9:00 PM (#296343 - in reply to #296342)
Subject: Re: Wanted-Breadwinner PU selector toggle
send me an email mileskb at aol.com
Posted 2008-12-31 9:11 PM (#296344 - in reply to #296342)
Can you obtain a picture and possibly any ID number on the unit?
And Welcome!
Probably the 4PDT, On-On-On with the longer Wire lugs.
Squarepeg
Posted 2009-01-03 7:59 AM (#296345 - in reply to #296342)
December 2008
I haven't taken it apart; it's still strung up. It should be Ovation part #487002-X-15 (Selector Switch JBT J0331). I'm guessing it's on-on-on.
numbfingers
Posted 2009-01-03 10:41 AM (#296346 - in reply to #296342)
Don't count on it, unless Miles has told you that all these switches are the same. There were several versions of the preamp and they use some weird custom parts. Woody's suggestion to get positive ID is a good one.
-Steve W.
Posted 2009-01-03 12:42 PM (#296347 - in reply to #296342)
how many you need?
Posted 2009-01-03 2:35 PM (#296348 - in reply to #296342)
To my knowledge, unless someone has rewired the pre-amp there are two switches. A 4P3T and a 3PDT, the larger being the pickup selector.
If it has been re-wired, then putting the correct switch in as a replacement should be easy enough unless someone butchered the board.
Posted 2009-01-03 5:33 PM (#296349 - in reply to #296342)
RE: "Woody's suggestion to get positive ID is a good one."
For the record, I am between 5'8" and 6'2" depending on which Seven-Eleven I was last seen exiting.
Squarepeg
Posted 2009-01-03 10:38 PM (#296350 - in reply to #296342)
December 2008
I believe it's all original; it's an early model, serial #E00093.
