Solidbody Frets
AussieJames
Posted 2008-08-21 7:23 PM (#24906)
Subject: Solidbody Frets
June 2007
Can someone tell me if the frets on the Breadwinners, Vipers etc with ebony finger board were glued or just pressed in at the factory?
Thanks
AJ
muzza
Posted 2008-08-21 10:18 PM (#24907 - in reply to #24906)
Subject: Re: Solidbody Frets
August 2005
You could try emailing the factory...
AussieJames
Posted 2008-08-22 1:29 AM (#24908 - in reply to #24906)
June 2007
I will have to, figured someone here would know
Posted 2008-08-22 1:31 AM (#24909 - in reply to #24906)
As far as I know the frets are pressed in, not glued. I also believe that the frets are "proprietary" as in... you won't find fret wire anywhere else that's exactly the same.
Mauvis Beal may have some additional or more accurate info.
AussieJames
Posted 2008-08-22 2:15 AM (#24910 - in reply to #24906)
June 2007
Thanks Miles,
My luthier asked the question.
I've had a couple with some loose frets.
AJ
Posted 2008-08-22 8:09 AM (#24911 - in reply to #24906)
At first they were just pressed but later on they were probably glued in, like all the production.
