Location: Townsville, Australia | Somewhere I read that ovations are likely to get warped tops within 3 years due to the different rates of expansion between the composite body and wood top.' And that this makes them a disposable item
Is there any truth in this |
Location: Warren,Pa. | Quote: "A person with an experience is NEVER at the mercy of a person with a theory." I suspect that what you read was written by a person with little or no experience with Ovations. John <>{ |
Location: GATLINBURG TENNESSEE :) | I have two wood topped guitars that are 25-30 years old, and neither has even a ripple of warpage. Sounds like you have bad info. I imagine you could make any guitar warp if you you didn't properly care for it. |
Total bullshit. Yes there are forums on the internet where you could read such things. Doesn't make it true.
PS - Welcome to the club. Where is Townsville? I've heard of Toneville. Are they by any chance the same place? |
Location: 6 String Ranch | A complete load of old cobblers.
Welcome to the club. |
Location: NW NJ | Hobie - I'm so glad that you had the excellent sense to ask the question in a forum of people who have extensive actual (not theoretical) experience with real Ovation guitars. The answers you've gotten above summ up the truth perfectly. Things like you heard about Ovations come from people who are terrified of other people and companies who think outside the "box". That's probably why I like Ovations so much.
Actually, I heard that, unless the entire instrument is made out of the same species of wood, from the same tree; totally wooden, box guitars tend to have their tops split, fretboards curl, and their sides and backs separate because of the different expansion rates that multi-variate wood combinations exibit ... well, that's what I heard! :D |
Location: Boise, Idaho | Lets, see. 33, 30, 29, 23, OK too much math for a Monday morning. No warps on those or any of the "newer" ones. My youngest Ovation is 7. No warped tops. |
Location: Phoenix AZ | To be fair to Hobie, you may see older guitars where the top is not perfectly flat. But I think has to do with the odd-ball bracing patterns and is not at all related to the fact that the back of the guitar is made of plastic. Dave |
Location: Upper Left USA | The world is flat and Ovations are round. Only slightly on the Tops though! |
Location: Boise, Idaho | Originally posted by Standingovation:
To be fair to Hobie, you may see older guitars where the top is not perfectly flat. But I think has to do with the odd-ball bracing patterns and is not at all related to the fact that the back of the guitar is made of plastic. Dave True. On a couple of mine, if you look at the right angles you can see where the braces are underneath. Since I have no woodbox guitars, I have nothing to compare. |
Location: Warren,Pa. | So...the backs of Ovation guitars ARE made of plastic?!?! Man...this is the place to find out the REAL truth! |
Location: Phoenix AZ | Originally posted by bauerhillboy:
So...the backs of Ovation guitars ARE made of plastic?!?! Yeah. What would YOU call it? I know, I've been fighting the lyrachord, microsphere, high-tech, poly schniz-nit, whateverdahell it is syndrome for 35 years. 99.9% of the world thinks the bowl on an ovation guitar is plastic, therefor it's plastic. It isn't my job or personal crusade to change the rest of the world's bigoted ideas about ovations. It's like trying to shove an ice cube into a parking meter. I know what I like, and THAT's all that matters.
Dave |
1. Any of various organic compounds produced by polymerization, capable of being molded, extruded, cast into various shapes and films, or drawn into filaments used as textile fibers.
I yams what I yams!
I agree with Dave. |
Location: 6 String Ranch | Shove an ice cube in a parking meter!!!
You shove 1" washers in a parking meter! I thought everyone knew that. |
D'ya remember when Necco wafers used to work in the toll baskets of the CT Turnpike?? |
Location: 6 String Ranch | It was truely a beautiful thing!
And then there were the old pay phones that you could drop a penny (or a nickle if you weren't that good) in and hit the coin return at just the right time as the coin fell and get connected. |
Location: ms | As I looked at my 92 collectors, after removing shim after shim, sanding, and the top continuing to rise, and after seeing many pawnshop prizes, with the tops rising and seperating, I can't help but believe that there is a problem. Maybe the reason most of you guys haven't had this problem is because of the care you give your instruments. Maybe the problem with these pawnshop prizes is the way they were treated. I've just seen this too many times on mainly older ovations, not to believe something is going on. Granted, you see this on other makes just seems not near as often. I know this statment won't make me the most popular guy on the block, and I love my ovations and am looking foward to owning more, I'm just sharing my personal experience.
Peace,love,and hippie music :) |
Location: Phoenix AZ | Gulfcoast, The problem isn't the top... It's the plastic. Trust me, I read this onthe Martin forum and I know those guys would not steer me wrong. Dave
PS - I honestly think the issue is/was the bracing. You don't see this "problem" on modern Ovations, X and A braced. And I really question if it is problem. So what if the top isn't flat. Maybe that makes it sound better? |
Location: Boise, Idaho | It's not the care in my case. My 73 CA, I just got and it has cracks and a couple dents in the top, but I can't see any warp. The 77 Folklore has a little belly below the bridge. It had a brace that was coming loose and that may allow it to happen. The Classic has ripples where the braces are. Don't know how it was cared for during it's first 15 years, but the rest of the guitar is immaculate, so it may have sat in a case or hanging on a wall. I just figured that the cedar top was softer. Tired of looking for ghosts. |
Well those responses are reassuring. I will continue to look at getting an ovation.
Hobie
PS Townsville is in far north queensland, East Coast of Australia |
Location: Atlanta, GA. | Toneville is in far north of Ohio, southern shore of Lake Erie!
BTW... Ground Start payphones were pretty cool too!!! |
