how do I adjust neck
diesel
Posted 2008-09-03 10:33 AM (#22550)
Subject: how do I adjust neck
September 2008
I am loving this eclipse more every day as I play it,but my strings are really high at the bottom and low at the top. The saddle is down as low as possible. I took the cover off the back and it has an allen, is this to adjust angle. The neck appears fine as far as truss adjustment but action is way to high at bottom only.any help?
diesel
Posted 2008-09-03 12:41 PM (#22551 - in reply to #22550)
Subject: Re: how do I adjust neck
September 2008
Figured it out. All adjusted.Sorry for asking so many newbe questions.I checked out a bunch of the threads on the site and you guys have a great thing started here.
Posted 2008-09-03 1:22 PM (#22552 - in reply to #22550)
Don't be Sorry Diesel... I'm just disappointed that you didn't get a dozen answers.
I woulda liked the education.
I think you and DVD are the only two members who own the Eclipse.
(If I'm wrong, someone will tell me)
I saw DVD's once in person and it seemed like a fine guitar to me.
dvd
Posted 2008-09-03 2:46 PM (#22553 - in reply to #22550)
There are several more around. AussieJames, MisterGolf007, others. There's a non-OFCer up in Battle Ground that puts one up on the Portland Craigslist once in a while that never seems to sell.
Oh and Diesel beat everybody to the punch. Loosen up the neck bolts a bit, and then tweak that center allen bolt to control the angle of the dangle.
Posted 2008-09-03 3:24 PM (#22554 - in reply to #22550)
diesel,
Sorry I missed the post. Probably because it wasn't about me!
I'm really proud of my humility though...
Try backing off the two neck screws closest to the bridge about a 1/4 turn. Then tighten the forward two 1/4 turn. Now raise your Bridge accordingly.
The allen doodad is a pivot point and the neck bolts are the "levers.
It may take a few trys to get it to stay in the perfect spot but once you get the hang of it you can set it up perfectly for your style.
Then we'll discuss intonation and string gage...
diesel
Posted 2008-09-03 5:59 PM (#22555 - in reply to #22550)
September 2008
I loosened all 4 and then moved the allen inward and then retightend all 4.I am getting ready to set intonation and all I had on hand was a new set of D'Addario super lights 9-42. I think this is to light but it needed strings.I will pick up some this weekend.Any sugestions?
Posted 2008-09-03 6:31 PM (#22556 - in reply to #22550)
Opinions on strings are plentiful.
I suggest D'Addarios with a .010" e string.
You can fatten up on the bass strings or stay light.
Posted 2008-09-03 10:04 PM (#22557 - in reply to #22550)
I always liked stainless. I use an 11 set but you should start with a 10 set. Nickle feel a little grittier to me.
Posted 2008-09-03 11:20 PM (#22558 - in reply to #22550)
It takes a while to figure out what you like on that particular guitar.
Basically, steel strings will brighten your tone. Nickle plating mellows the sound, pure nickel is really mellow and flat rounds the mellowist. Once you start to distort the difference is negligable. I say start light and bright, then go thru heavier and mellower, then heavy and bright. Most people wind up in the middle.
