OP Pro Problems
Tommy M.
Posted 2006-06-09 9:40 PM (#251616)
Subject: OP Pro Problems
January 2004
The strangest occurrence is happening on my LX1777, when I play it through my new PA System. After about 2 minutes of playing, it distorts and then dies completely. My first response was OK, change the battery, same thing happened. I played the same guitar through my acoustic amp, and tape deck, no problem. My other acoustic electrics, work fine through the PA, why this OP Pro LX 1777LX dies after 2 minutes in the PA head baffles me. Anyone ever heard of this?
TexasDoc
Posted 2006-06-09 10:57 PM (#251617 - in reply to #251616)
Subject: Re: OP Pro Problems
Running thru 1/4 inch or XLR? Try different cables. Are you running phantom power? If it works with an amp, shouldn't be the guitar. Is the PA not sending stable phantom power? Is your cable's ground pin shorting? If you are using XLR, try a different cable or plug in a 1/4 inch plug/cable to energize the OpPro with the battery.
Tommy M.
Posted 2006-06-09 11:43 PM (#251618 - in reply to #251616)
January 2004
Using 1/4 inch jack. Tried different jacks, too. No phantom power in use. My other guitars work fine through the PA.
TexasDoc
Posted 2006-06-09 11:52 PM (#251619 - in reply to #251616)
But it works thru an amp?
Tommy M.
Posted 2006-06-10 12:09 AM (#251620 - in reply to #251616)
January 2004
Yes, that's the mystery.
BruDeV
Posted 2006-06-10 4:40 PM (#251621 - in reply to #251616)
Have you tryed a different channel on the PA?
Posted 2006-06-10 5:11 PM (#251622 - in reply to #251616)
You tried different cords?
