CELEBRITY DELUXE Model CS257
Butch
Posted 2006-06-14 9:25 AM (#251167)
Subject: CELEBRITY DELUXE Model CS257
:confused:
If I put (Classical / Nylon) Strings on It..
Will The Pickup work with This Type Of Strings ?
Posted 2006-06-14 11:15 AM (#251168 - in reply to #251167)
Subject: Re: CELEBRITY DELUXE Model CS257
I'd worry about the other end. The slots in the nut may not be wide enough for the nylons. The action should also be higher for nylon strings, so you may have to raise the saddle. Try it and see. You'd only be out a set of strings if it doesn't work.
