PA system setup question
Shandy Glover
Posted 2006-06-19 3:16 PM (#250072)
Subject: PA system setup question
I am not much of an electronics guy but can any of you tell me if I have a PA mixer head that is pushing out 200watts and I have 4 speakers that will carry 60watts each, will my speakers suffer any damage? One person told me that you want more power on the head than in the speakers. He said problems occur when it's the other way around. Any info would be greatly appreciated.
ignimbyte
Posted 2006-06-19 10:39 PM (#250073 - in reply to #250072)
Subject: Re: PA system setup question
July 2004
With regards to PA systems, I don't have any knowledge about it either. Generalizing from what I learned about home audio, (as long as the electronics share the same impedance ... [e.g. 8 ohm amp = 8 ohm speakers]) I'd been told that it's better to have speakers that can handle more wattage than the amp or receiver's maximum output. For example, I have an old 80-watt receiver in my basement that I set-up with two pairs of book shelf speakers with a 10-watt minimum to drive, but can handle up to 120 watts max each. That's the way it's been set up for many years, and never had any problems with it. I can only guess that the extra 40 watts that the speakers could handle kept them from "blowing up" in all those years that I cranked up the volume when I used to listen to my favorite vinyls ... (this was before home theater became common in households). If it works with home audio, I will guess that it might work with PA systems, as well ...
then again, it's best to confer with the professional(s) about this matter.
Good luck.
