Location: gods country..west virginia | is there any other necks that will fit a matrix.. |
Location: gods country..west virginia | the paper lable is gone.the only other tag in it says ovation 115992..any clue on what the numbers mean?? |
Location: Upper Left USA | That is the Serial Number. |
Location: Boise, Idaho | I remember noticing a difference between how my Matrix is attached to the body and how the others are, but now I can't remember what I noticed. |
Location: gods country..west virginia | I had a moment of stupidity woody.. |
Location: gods country..west virginia | mine attaches with 2 bolts inside |
Location: gods country..west virginia | is there any other ovation necks that will fit a matrix?? |
Location: Boise, Idaho | I bet not. The Matrix bowl just has the holes for the 2 bolts. You'd have to cut the bowl to fit the other type of neck. Maybe possible, but not easy and if you ruin the bowl trying to set the neck, you're hosed. |
Location: gods country..west virginia | its playable and sounds good for a $90 yard sale find, the action is kinda high but not to high that its unplayable. only thing it needs is a saddle and a refinish job,no cracks in the top just finish cracks...i can live with the action. thanks jason. i got 2 of them any how. the other needs machines. |
Location: Canton (Detroit), MI | Applause AA14 might...they were similar.
Roger |
Location: gods country..west virginia | thanks, looks like i have to live with the finish crack,just got a email from kim keller..refinishimg the matrix is a tricky deal..oh well it plays great for a yardsale throw away. |
Get a .072 Phospher Bronze from www.juststrings.com and put it in place of your "E" string. Then use a medium set of strings but put the .052 (or whatever) in place of the "A" and so on.
Tune BEADF#E for a Poor Man's Baritone. |
Location: gods country..west virginia | thanks woody, i found something strange when i pulled the saddle out to put the new one in. the old one was cut down and had 2 plastic q-tip shafts under it...verry strange |
Location: Upper Left USA | Use cut up Credit Cards for shims. |
Location: gods country..west virginia | i used my old d.l from west virginia, the first few frets had some wear on them and the action was so low you couldnt get a clear note out of it. i set it i bit higher and it sounds great now..looks like shit but sounds great. |
