new 1773 LX buzz
elkabyle
Posted 2006-10-13 10:23 AM (#236531)
Subject: new 1773 LX buzz
March 2006
My new 1773 LX gives me troubles. If I play certain notes on the neck I hear a buzz. It does not happen when I removed the pre-amp from the guitar body. Any idea????
Posted 2006-10-13 10:27 AM (#236532 - in reply to #236531)
Subject: Re: new 1773 LX buzz
the preamp rattles. try to tighten the pre amp box
elkabyle
Posted 2006-10-13 10:29 AM (#236533 - in reply to #236531)
March 2006
How do I tighten the pre amp box?
Posted 2006-10-13 10:35 AM (#236534 - in reply to #236531)
Pop the preamp out and you'll see a screwhead on each end of the can. Tighten them (don't use excessive force).
elkabyle
Posted 2006-10-13 10:45 AM (#236535 - in reply to #236531)
March 2006
ok will try tonight.
Thanks for your advice !!!
elkabyle
Posted 2006-10-23 10:58 AM (#236536 - in reply to #236531)
March 2006
I didn't have much success tightening the 2 screws. The rattling varies when I tighten/untighten the screws but I can't get rid of the rattling completely.
Posted 2006-10-23 11:06 AM (#236537 - in reply to #236531)
then you need to put some sort of foam between the can and the preamp.
this is the only time i heard of this problem.
elkabyle
Posted 2006-10-23 11:43 AM (#236538 - in reply to #236531)
March 2006
I bought this guitar from you Al, back in March this year. I'm not in the US anymore otherwise I would have sent it back to you for a check.
I'm in the Uk and I don't know if there's an Ovation repair shop in London.
Posted 2006-10-23 12:29 PM (#236539 - in reply to #236531)
I have had to chase the "buzz" and have found it to be on the staploc washer/strap part occasionally.
Inside wires as well.
Try removing the preamp and see (listen) as well.
elkabyle
Posted 2006-10-23 12:40 PM (#236540 - in reply to #236531)
March 2006
what are staploc washer/strap part? where are they? in the preamp?
Posted 2006-10-23 12:46 PM (#236541 - in reply to #236531)
On the pins where you put on the strap (iff applicable).
As funny as it MAY sound, check all of the machine head hardware. Make sure that the tuning peg washers are snugged-down. Alot of times, errant vibrations/rattles can travel down the neck only to be amplified by the soundboard and make it APPEAR that the "buzz" is coming from inside the body . . .
Posted 2006-10-23 12:47 PM (#236542 - in reply to #236531)
They are the washer/pin/washer/"C" ring assembly on the strap if you use the Straploc type. If not tight the washer can buzz.
Very hard to isolate.
elkabyle
Posted 2006-10-23 12:51 PM (#236543 - in reply to #236531)
March 2006
mhhh... now that you mention tuning pegs, I realize that the rattling noise happened shortly after I change one broken string.
I will have a look tonight.
elkabyle
Posted 2006-10-24 5:32 AM (#236544 - in reply to #236531)
March 2006
ok... I've fiddled with the preamp, removed it from its box, removed the battery, put it back in, put the preamp back into its box and the rattling noise disappeared completely.
Still a mystery as far as I'm concerned but hey can't complain.
Thanks everyone for the advices.
