Breadwinner Electronics help...
baconJuice
Posted 2006-10-21 3:16 PM (#235358)
Subject: Breadwinner Electronics help...
Hello All,
I just purchased a Breadwinner from craigslist here in Austin. I could not believe my eyes when I saw that posting. I have been looking for one of these guitars for a while and suddenly there it was, I had to get it.
Anyway, although the guitar is in great shape, I am having trouble with the electronics. The tone knob doesn't seem to do anything and the Notch filter switch just makes signal even weaker than it already is. I took the electronic board out and it looks like there was a modification made to it. There are a cople of extra wires that I don't think are original but it looks like they have been there a long time. I took a picture it is here...
http://www.flickr.com/photos/13965576@N00/275496622/
Any help in figuring this out would be great. I have the schematic from the breadwinner fan page and I am slowly going through the circuit now, but any help you guys can offer would be great. thanks
Julio
Posted 2006-10-21 4:13 PM (#235359 - in reply to #235358)
Subject: Re: Breadwinner Electronics help...
Basically they bypassed the pre-amp, sortof.. Remove those two jumper wires. They don't belong. Someone may have just done this to bypass the pre-amp without destroying it, so just remove them and see if the pre-amp works. And remember the selector switch is BOTH-Bridge-Neck not the normal Bridge-BOTH-Neck.
baconJuice
Posted 2006-10-21 4:45 PM (#235360 - in reply to #235358)
Excellent, thanks for the help. I will remove those wires and check the rest of the electronics. hopefully, that is all it needs.
BruDeV
Posted 2006-10-21 10:17 PM (#235361 - in reply to #235358)
Almost looks like traces 1 & 2 are shorted in the circled area. Make sure they are not.
baconJuice
Posted 2006-10-22 1:28 PM (#235362 - in reply to #235358)
Good eye BruDeV! That connection was indeed bridged and I fixed it, unfortunately, the pre-amp still does not work. I guess that is why it was being bypassed. :( I'm sure it is fixable, it's just going to take some time to go through the board find the problem. oh well, back to the bench it goes.
Posted 2006-10-22 4:27 PM (#235363 - in reply to #235358)
I get questions all the time, about pre-amps that have no input signal. I've been lucky enough that most of the pre-amp issues I have had or had to fix were physical. Part missing, or broke. But I have a few that have the same symtom. You can hear the tone and notch filter change the "noise" on the output, but no input at all, pickups are fine. Is there a known weak point on the input before I go dig out my scope, signal generator, freq counter etc...
Melmoth
Posted 2006-10-23 10:22 AM (#235364 - in reply to #235358)
February 2006
Bacon: There are high-res schematics of the preamp in PDF on my site:
http://gewalker.googlepages.com/Ovation_Breadwinner_Schematic.pdf
They might help as well.
baconJuice
Posted 2006-10-23 1:20 PM (#235365 - in reply to #235358)
It's alive!!!
Many thanks to all of you for your help and advice. The problem was being caused by the switch inside the 1/4" jack, it was not making contact. I just unsoldered it pushed the contact out a bit and soldered it back on and voila, it was rockin' again.
Melmoth, thanks for the hig-res schematic images these will come in handy. Comparing the circuit on my board to the schematic, it seems that my board didn't exactly match the two drawings. I wonder if there is a 1251-0-350 E revision? Oh well, its working now. :)
Thanks again for the help..
Julio
Melmoth
Posted 2006-10-23 1:50 PM (#235366 - in reply to #235358)
February 2006
That looks like a rev-F board to me. Keep in mind that it can be tough to match up a schematic to a pcb at times.
BruDeV
Posted 2006-10-23 5:13 PM (#235367 - in reply to #235358)
I've usually had problems with R10a, if it wears out it opens the signal path. An easy way to check is to short across it; the pre-amp will work, but the tone level compensation won't.
baconJuice
Posted 2006-10-24 12:17 PM (#235368 - in reply to #235358)
Well, sure enough more problems have arisen. The guitar works great for a while. After about an hour or so, sometimes shorter, it starts to make a whole lot of noise and the pickups stop working. It will stay in this state until it is unplugged for a couple of minutes then plugged back in. Sometimes however, toggling the notch filter makes it come back. Does that sound farmiliar to anyone? Maybe its being caused by a dying capacitor?
That is an excellent schematic BruDeV. Thanks!
Posted 2006-10-24 12:26 PM (#235369 - in reply to #235358)
Electric geek porn. Hands where we can see 'em fellers.
Posted 2006-10-24 1:21 PM (#235370 - in reply to #235358)
Careful, they're known for their resistance...
Posted 2006-10-24 1:34 PM (#235371 - in reply to #235358)
"Ooooooh! . . you're a "Dirty Girl", aren't you?? . ."
-Robbie the Robot
baconJuice
Posted 2006-10-24 1:49 PM (#235372 - in reply to #235358)
well, this thread took an weird turn....
Posted 2006-10-24 1:52 PM (#235373 - in reply to #235358)
not taking a weird turn, would be a weird turn...
Posted 2006-10-24 2:35 PM (#235374 - in reply to #235358)
". . well, this thread took an weird turn . ."
How many newbies have typed THAT utterance? . . .
baconJuice
Posted 2006-10-26 6:56 PM (#235375 - in reply to #235358)
Well, I think I found the cause of the weirnesses. After much tracing with a tone generator and an oscilloscope, I tracked the problem down to one of the JFETs - Q3. As it turns out finding a place that has these transistors in stock was just as difficult as finding a bad one in a circuit. I finally had to order some from Mouser electronics. Well, at least it will be fixed for good...(crosses fingers)
