Slight bulge on 1537
JeffreyD
Posted 2006-11-07 7:12 PM (#232657)
Subject: Slight bulge on 1537
September 2004
The other night I while I was cleaning the 1537, I noticed an ever so slight hump just behind the bridge. It wasn't really visible, but I could definately feel the variation. Hadn't noticed it before.
Is this something to be concerned with. The guitar is is really good shape except for one finish crack so I have held off sending it in for a refurb, but maybe it is time if that is necessary to preserve it. I backed the strings off a bit and put it away, but I remain curious.
pzavislak
Posted 2006-11-07 7:18 PM (#232658 - in reply to #232657)
Subject: Re: Slight bulge on 1537
I think the way they set the top at the factory is so that it is slightly arched upwards. Isn't it supposed to give the guitar less dramatic changes in response to changes in humidity?
Posted 2006-11-07 7:18 PM (#232659 - in reply to #232657)
My feeling on this sorta bulge is well documented on this site...
most all old guitars show some sign of this... that's what makes them sound good
JeffreyD
Posted 2006-11-07 7:29 PM (#232660 - in reply to #232657)
September 2004
Cool....won't sweat it then. Thanks....
Posted 2006-11-07 7:30 PM (#232661 - in reply to #232657)
Perfectly normal. Don't worry about it.
Posted 2006-11-07 7:58 PM (#232662 - in reply to #232657)
Nice add Jeff....feel the pc police breathing hard down your neck???
Bradley
Posted 2006-11-07 9:33 PM (#232663 - in reply to #232657)
Although I agree with what the others said, its that time of year where we all need reminding. A bulge along with a dip in front of the bridge is a sign of lack of humidity. This year I bought a room hygrometer as well as three hygrometers for three of my guitars to keep a better eye on the RH level. My hand made GOM Redwood/Walnut guitar that I received this year had a bit of a hump behind the bridge. It turned out to be too much humidity. I was keeping the guitar in the case when not in use only to find out that the RH in the case was 15% higher than the room. The luthier said that in the summer I should leave the guitar out more so that it can dry out a bit, and in the winter... well my Ovation Custom Legend is a constant reminder of what can happen due to dryness in the winter. The top cracked, bulged behind the bridges and dips in front of the bridge.
Jason_S
Posted 2006-11-07 9:38 PM (#232664 - in reply to #232657)
all my ovations have had cracks,dips,bulges..my balladeer has a bulge behind the bridge,3 cracks,recently repaired severed headstock and it sounds great...adds to the sound of 30+yr old spruce..jason
stellarjim
Posted 2006-11-07 10:53 PM (#232665 - in reply to #232657)
Jeff:
Don't worry too much. I had a 1718 very much like that for years and everyone raved about how good it sounded. Had many people offer to buy it from me, hump and all.
Jim
edensharvest
Posted 2006-11-08 2:07 AM (#232666 - in reply to #232657)
March 2006
I've seen it a couple times. Personally after comparing 2 identical CL's, one with a hump, one without, the "humpy" one sounded WAY better. Louder, fuller, and better sustain. Just the top in prime condition.
Just watch to make sure it doesn't get severe. Other than that, enjoy.
Posted 2006-11-08 5:24 AM (#232667 - in reply to #232657)
No it's not. Changes in humidity levels may cause a dip to become more or less apparent, but if the top is sinking between the bridge and soundhole it's generally not a result of climatic conditions but a sign of potentially serious structural problems.
If a flat-top guitar doesn't show a very slight hump behind the bridge it's usually because it's built too heavily. (Carbon tops being the exception) A sinking top is a whole other thing
Jason_S
Posted 2006-11-08 5:43 AM (#232668 - in reply to #232657)
broken braces will do it,rember the matrix i had at the gathering temp? it had several broken braces. the top was sinking between the bridge and the upper bout..
if it gets too bad serious shit can happen..ive got pics of the matrix after the top finaly gave way...jason
worshipleader
Posted 2006-11-08 9:01 AM (#232669 - in reply to #232657)
June 2004
That would qualify as serious ... :D
Jason_S
Posted 2006-11-08 9:08 AM (#232670 - in reply to #232657)
temp was the last person to play that one..after we got home and unpacked i set out to change strings on my guitars,i started to bring the exp 13's up to tension then she started cracking...oh well that was the best $25.00 ive ever spent. i had that one since i was 16....jason
gh1
Posted 2006-11-08 9:24 AM (#232671 - in reply to #232657)
It's been "raining cats and dogs" here in the PNW with warm temperatures. The RH is 80 - 90% and all of my guitars sound flat and the intonation has gone to hell. The normally rock solid tuning is a mess.
I suspect the tops are moving all over the place, but i really can't see any physical changes. What's up with that!?
_____
gh1
Jason_S
Posted 2006-11-08 9:33 AM (#232672 - in reply to #232657)
its raining like hell here here in maryland too..jason
Posted 2006-11-08 11:16 AM (#232673 - in reply to #232657)
My sweet Gertrude (1111-4) has a split from the bowl edge to her bridge (which was so skillfully repaired at the Mothership that it's barely noticeable), and the undulations in her top come and go. Sometimes a little wavy, sometimes almost perfectly flat. The changes don't seem to affect how she sounds (which is very mellow, rich and full), or her intonation, either--I just figure we're both aging at about the same rate. ;) (And there are days when I am sure Gertrude is winning.......)
--Karen
