REPAIRING A MODEL 1121
kres1121
Posted 2006-12-11 1:04 PM (#227285)
Subject: REPAIRING A MODEL 1121
CAN ANYONE SEND ME INFORMATION ON HOW TO REMOVE THE NECK ON A MODEL 1121-4 SERIAL # 011227. I NEED TO REPAIR THE SOUND BOARD - SEVERAL LARGE CRACKS AND SPLITS, ALSO NEED TO RAPIR SOME ROUGH SPOTS ON THE NECK.
THANKS
Jason_S
Posted 2006-12-11 1:59 PM (#227286 - in reply to #227285)
Subject: Re: REPAIRING A MODEL 1121
if its just cracks why not just fill em the easy way? ive got plenty of o's that ive repaird tops on and sound damn fine? i wouldnt f@ck with a set neck personaly....just my opinion..take it for what its worth...jason
HobbyPicker
Posted 2006-12-12 5:37 AM (#227287 - in reply to #227285)
Here's a page from a Norwegian luthier showing some pics from repair of cracks in an ovation top. Norsk Gitar as - sprekk i lokk
Posted 2006-12-13 1:19 PM (#227288 - in reply to #227285)
Stop shouting. There's people trying to sleep here.
kres1121
Posted 2006-12-18 4:37 PM (#227289 - in reply to #227285)
After ya'll repaired the cracks and all what kind of finish did you use. Did you paint it or stain it, then reseal it?
Jason_S
Posted 2006-12-18 4:41 PM (#227290 - in reply to #227285)
lots and lots of sanding with superfine grit paper or finishing pads from stew mac. keep it wet!! i used soapy water as a lube when i finished the top on the 1111 i sold eddie...it takes a lot of time,go slow. i went thru the cya quite a few times the first time i filled cracks in a top. if you do it right it looks quite good...jason
you cant reseal a catilized polyester finish that ovation uses, you just have to sand and buff the filled cracks and the area around the repair till the scratches and sworls are gone and it blends in with the rest of the finish....jason
Posted 2006-12-18 4:43 PM (#227291 - in reply to #227285)
Ovation uses a Poly finish. When you use the Cyano-glues to fill it leaves poly behind. You then use polishing steps to flatten and polish.
You can't put lacquer over Poly.
Jason_S
Posted 2006-12-18 4:44 PM (#227292 - in reply to #227285)
was i somewhat close to the right directions mike?? jason
Jason_S
Posted 2006-12-18 4:47 PM (#227293 - in reply to #227285)
filled cracks in a balladeer top, they are in the left lower bout....
