Tail Piece anyone? What's going on here?
Posted 2008-09-22 11:22 PM (#19228)
Subject: Tail Piece anyone? What's going on here?
"No problems at all."
One wonders, yes one does.....
Pacemaker on the \'Bay
Posted 2008-09-22 11:40 PM (#19229 - in reply to #19228)
Subject: Re: Tail Piece anyone? What's going on here?
It probably had a lifting Bridge.
Posted 2008-09-23 12:00 AM (#19230 - in reply to #19228)
it's priced right
Gallerinski
Posted 2008-09-23 12:07 AM (#19231 - in reply to #19228)
The sad part is that you can be pretty darn sure that the (presently) 1 bid is from an OFC member.
Dave *RIP 282*
Posted 2008-09-23 8:00 AM (#19232 - in reply to #19228)
If you could buy it cheap enough, you could send it to the factory for a "spa" visit.....
RIP.... Remember
Gallerinski
Posted 2008-09-23 8:45 AM (#19233 - in reply to #19228)
Actually a 12 string trap trailpiece isn't cheap so maybe worth buying just to have as a spare part for your Hurricane.
Posted 2008-09-23 8:52 AM (#19234 - in reply to #19228)
I'm looking at the 'little crack that barely goes through' the back of the headstock, and into the slot... First time Fed Ex drops that, it's history. But yeah, buy it cheap and send it to Mom!
Posted 2008-09-23 9:32 AM (#19235 - in reply to #19228)
Dave *RIP 282*
It isn't me. I'm tapped at the moment. (Not that it would matter.) :p
Posted 2008-09-23 12:16 PM (#19236 - in reply to #19228)
"The sad part is that you can be pretty darn sure that the (presently) 1 bid is from an OFC member."
Twas I.
Once you start chasing ambulances its hard to stop. My bid was for $7.77, made mostly so I could track it easier.
It's a sickness without cure... only treatment and therapy.
BTW - Someone want to explain to AJ what "intervention" means?
:eek:
Gallerinski
Posted 2008-09-23 12:49 PM (#19237 - in reply to #19228)
I rest my case.
Posted 2008-09-23 12:59 PM (#19238 - in reply to #19228)
"The point, Oblio, is that everything must have a point!"
Posted 2008-09-23 7:57 PM (#19239 - in reply to #19228)
Well, if I'm dammned to spend eternity as an Arizona Roof Repairman I guess this will be the clincher...
Mandolin with aterations
Posted 2008-09-23 10:44 PM (#19240 - in reply to #19228)
90 is pretty high for that.
Posted 2008-09-24 12:41 AM (#19241 - in reply to #19228)
Well, I separated the neck and sanded down the top tonight. I don't think he'll take it back.
It most likely will end up with a Koa top layer and some Abalone around the edges.
...and a new bridge of course.
I'm a hack Mando player and it will always be plugged in so I get to practice on this one.
Just old Woodworker with more inspiration than talent. Whaddya goin do but try?
