OP-24 Electronics
Chuck (Retired Navy)
Posted 2002-07-13 7:46 PM (#220282)
Subject: OP-24 Electronics
July 2002
I have a 1711 Balladeer with the OP-24 electronics. My son says that he can hear a slight buzzing when I plug in to an amp coming from the speaker. I was using the mic input on my tape deck, running it througha 100 watt stereo amplifierI had just put a fresh battery in. When I reduced the gain the buzzing went down in volume. Is there anything that can be done to remove the noise, or do I have to have the electronics replaced?
Chuck
Posted 2002-07-13 9:23 PM (#220283 - in reply to #220282)
Subject: Re: OP-24 Electronics
You can be pretty sure that the problems are not being caused by the OP24, try using some pro sound equipment rather than a hi-fi & make sure all your cables are of good quality & are in good condition.
[ July 14, 2002: Message edited by: Paul Templeman ]
Posted 2002-07-14 4:09 PM (#220284 - in reply to #220282)
July 2002
Thanks. I will have to pick up a new cable this week and see if it makes a difference.
Chuck
