Ovation Solid Body Electrics
Rory
Posted 2002-11-18 2:34 AM (#216095)
Subject: Ovation Solid Body Electrics
Hmm, besides the Ultra GS, none of the solid bodies seem to have a tremolo system, am I correct?
Posted 2002-11-18 7:19 AM (#216096 - in reply to #216095)
Subject: Re: Ovation Solid Body Electrics
correct but real guitar players don't need no stinking trem
Posted 2002-11-18 11:47 AM (#216097 - in reply to #216095)
'cept for those Cali dudes who like to play some bitchin' surf licks, and wish their single coil Vipers had a trem because they can make a righteous surf sound through a fender with 'verb and trem. Wouldn't need to haul out the Strat and Surfcaster as often ...
Posted 2002-11-18 12:47 PM (#216098 - in reply to #216095)
just learn to bend with your fingers
Posted 2002-11-18 1:16 PM (#216099 - in reply to #216095)
Have already learned to bend notes up with the fingers, but am having trouble figuring out how to bend notes down ... ;)
As far as the next lesson on how to bend over ... methinks they're be a lot suggestions from this board. :D
Posted 2002-11-18 2:09 PM (#216100 - in reply to #216095)
You're probably correct, CabinBoy! Hell, I can't even get MY fingers to bend!!
Rory
Posted 2002-11-18 3:50 PM (#216101 - in reply to #216095)
Comon, Eddie Vanhalen was an awesome guitar player who relied a lot on the trem to make some awesome sounds.
Posted 2002-11-18 3:52 PM (#216102 - in reply to #216095)
Bending a note down... that's easy...
The following intructions are NOT for the faint of heart.
During the early 80's I played heavier pop rock. I didn't have a trem on my Viper at that time.. (I eventuially retrofitted and Kahler). The trick is easiest to do on notes/chords located within the first 5 frets, or just an open harmonic pulse.. (like the VanHalen version of Pretty Woman or Deep Purple's smoke on the Water or that annoying pulsed hold note in Boston's More than a Feeling)..
Play the note... insure the lower bout of the guitar is supported by your hip, apply pressure with your right hand and to the upper-bout.. BUT JUST A LITTLE... YOU ARE BENDING THE NECK AT THE MOUNTING POINT AND CAN SNAP THE NECK RIGHT OFF THE GUITAR IF YOU PUSH TO HARD!!!!!
I never broke the guitar... and in fact, those Viper necks are so sturdy, I never needed an adjustment for many years.
Like I said... above.. YOU'VE BEEN WARNED!!! YOU CAN BREAK YOUR GUITAR and Don't camplain to me.
I still do this trick on occasion.. but and I've seen others do it... but BE CAREFUL...
Posted 2002-11-18 3:56 PM (#216103 - in reply to #216095)
Al, I suspect you are just teasing. You can bend notes up with your fingers, but you can't lower pitch, nor can you bend all six-strings simultaneously. I don't mind trems, (which strictly speaking should be called vibratos, as tremelo is a variation in volume, not pitch) but I'm more of a Bigsby wiggle kinda guy, rather than a Floyd-Rose divebomber.
Rory
Posted 2002-11-18 3:59 PM (#216104 - in reply to #216095)
Anyone played with a Trans-Trem? I've got to say that Steinberger trems are the best ones in my experience. I'd fit my Ultra GS with one if they weren't so darn expensive!
Posted 2002-11-18 4:20 PM (#216105 - in reply to #216095)
A small point but the bass that was part of the hard body line up had a Kahler trem on it too..
Posted 2002-11-18 5:53 PM (#216106 - in reply to #216095)
Paul I can simulate a trem with some chords. It comes from years of playing guitars without trems.
btw it is funny how you listen to stuff and develop a style. I never knew that you could pick with your fingers and "fingerpicked" with a pick trying to figure out how they got all those notes so quickly.
I developed a sort of pantamine slide not realizing that people used metal or glass for slides.
I know you probably don't believe me but there is a lot that can be accomplished just with your hands how you position the pick and how you attack the notes. sorry if I sounded sarcastic.
cwk those bass kahlers kept the speaker reconers in business
[ November 18, 2002: Message edited by: alpep ]
Posted 2002-11-18 8:34 PM (#216107 - in reply to #216095)
Al, I appreciate that personal techniques can be devoloped to emulate sounds, but just because you do that doesn't make if "right" or appropriate for other players. Your statements "real players don't need trems" and "learn to bend with your fingers" do not make any sense to me as both a musician and a teacher.
As for vibrato systems on Ovation solidbodies; My Bigsby-equipped Tornado was in the shop recently having the pickups potted & I used my UK11 for a few gigs instead. I found I missed the Bigsby so I started looking for a possible trem for the UK2. I found this:
http://www.schaller-guitarparts.de/1227.htm
This is a direct replacement for LP style tailpieces and looks like it will also work with the earlier wrapover-type LP bridge. Gibson tailpieces & Ovation bridge-posts share identical spacing, so if I'm right (and it's perfectly possible that I'm way off here) this will work with any USA Ovation solid. I have one on the way, so I'll keep you posted.
[ November 18, 2002: Message edited by: Paul Templeman ]
Posted 2002-11-18 9:09 PM (#216108 - in reply to #216095)
Paul
you have to realize that some of that was tongue in cheek.
as for that trem it has been done before and they don;'t work very well.
Posted 2002-11-18 9:52 PM (#216109 - in reply to #216095)
I read an interveiw with Vince Gill (damn good guitar player) a while back. Early in his career, he heard what he thought was a straight electric guitar and he learned to emulate those parts. It was only later that he found out the guitar player was using a B bender to get those sounds.
Paul, you gotta learn that Al doesn't descend into sarcasm, he lives there. It's an east coast thing.
Rory
Posted 2002-11-19 1:40 AM (#216110 - in reply to #216095)
woohoo, I just replaced the original Dimarzio Humbucker in my Ultra GS(the model which only houses a single Humbucker)with an EMG 89 Active Dual Mode Humbucker and it sounds amazing on both Humbucker and Single Coil mode!
