raising fret board
Norseman1
Posted 2003-01-02 12:27 PM (#214673)
Subject: raising fret board
As I have been playing the snot out of my 1117 Legend, I recently noticed that the fret board is raising or seperating right at the sound hole. On the Low E side of the soundhole, and along the rosette, and going about 3/4 inches toward the center of the soundhole, the fret board is seperated about1/16th of an inch. On the opposite side of the soundhole, I had previously repaired a crack in the rosette, and a slight seperation from the fretboard. In the previous case, I used an epoxy glue,because I was dealing mainly with the rosette, but with the current seperation, I am not sure what to do/use.
Elmers wood glue? Epoxy? Leave it alone?
The board still appears to be adhered well in the center of the fretboard, but both ends seem to be raising a little.
Any suggestions?
Also, I removed a shim from under the saddle on my Legend due to the action seeming a little higher. Is it possible that this could effect the richness of the sound I get, or is it just in my head?
Thanks again.
Norse(hope to keep my Legend around a few more years!)man1
ovation06057
Posted 2003-01-04 6:55 AM (#214674 - in reply to #214673)
Subject: Re: raising fret board
October 2002
epoxy to hold the board down.Although the epoxy may not adhear the the finish under the f/b .
removing the shim brings the saddle in contact with the wood maybe thats what your hearing to be different.Just a WAG... :cool:
Norseman1
Posted 2003-01-04 5:15 PM (#214675 - in reply to #214673)
Thank you.
Norse(I appreciate your advice)man1
Posted 2003-01-04 6:13 PM (#214676 - in reply to #214673)
Lower action means less sound. Higher action gives a better sound, possibly because it increases the string angle over the bridge. The ideal is a balance in the middle.
