MAGNUM 1 PARTS
Miles Wellbe
Posted 2003-01-30 3:21 AM (#213295)
Subject: MAGNUM 1 PARTS
I recently bought a Magnum 1 on Ebay.The two bridge post screws dont fit in the intended bridge holes.I cant anchor or bring the bridge down into the body cavity where it needs to sit anybody know where I can find the correct screws? as I dont think these ones are not the originals also is it normal for only the neck pick up to work when using the stereo jack?
Posted 2003-01-30 5:32 AM (#213296 - in reply to #213295)
Subject: Re: MAGNUM 1 PARTS
The stereo socket is designed to be used with a "Y" cord, TRS to 2 mono jacks. The tip carries the neck pickup signal & the ring carries the bridge. A studio insert cord will do the job.
THe bridge posts appear to be the same as used on the guitars (non-Schaller bridges) the factory may have some or some members of the board.
samova
Posted 2003-01-30 7:24 AM (#213297 - in reply to #213295)
I have a few magnum parts floating around here somewhere(if i could only find them).Email me and i will look this evening ....samova@aol.com
