I need your thoughts
bdbdbuck
Posted 2003-01-30 1:54 PM (#213266)
Subject: I need your thoughts
I recently got a really great deal on a celebrity at a pawn shop. $210 w/OHSC....just a few minutes ago, I plugged it in. Well...the Low E and the A don't have much voice at all. The rest of the strings have that Ovation thunder we all know and love. What could be wrong, and how do I fix it?
Thanks,
bd :mad:
Posted 2003-01-30 1:56 PM (#213267 - in reply to #213266)
Subject: Re: I need your thoughts
maybe the pickup is bad but change strings first and see if that helps
bdbdbuck
Posted 2003-01-30 2:02 PM (#213268 - in reply to #213266)
I kinda figured the pickup as the strings are fairly new, they have a lot of brilliance left. The guy must have tried new strings before he sold the thing. How much is the pickup gonna run me, and can I do it myself?
bd
Norseman1
Posted 2003-01-30 2:21 PM (#213269 - in reply to #213266)
Might be just the wayit is. My 1711 Balladeer sounds crisp and clear, but it doesn't have much lower end sound, mostly highs.
I switched to medium grade strings, and that has helped give her a little more punch, but still not booming.
Norse(unless my pick-up is bad as well...that's possible)man1
bdbdbuck
Posted 2003-01-30 2:27 PM (#213270 - in reply to #213266)
This is a very pronounced difference. I maxed the low eq and still just barely audible over the natural acoustic sound. I would like to fix it soon because I have the time right now and I know I won't later.
bd
Norseman1
Posted 2003-01-30 2:29 PM (#213271 - in reply to #213266)
I wish you luck with it, but this is where my expertise bows out to others on the board! Good Luck bd!
Norse(low tech.)man1
bdbdbuck
Posted 2003-01-30 2:34 PM (#213272 - in reply to #213266)
Thanks Norseman,
I have been reading some of the other posts and noticed that Photogazer is somewhere in Virginia, maybe I can enlist his expertise.
Thanks again,
bd
Posted 2003-01-30 2:46 PM (#213273 - in reply to #213266)
if it is the pickup the swap is relatively painless
bdbdbuck
Posted 2003-01-30 3:45 PM (#213274 - in reply to #213266)
Al,
I am going to assume it is the pickup. Can you hook me up with one?
Thanks,
bd
Thumbpicker
Posted 2003-02-02 11:09 AM (#213275 - in reply to #213266)
Hhave you checked the saddle? Sometimes the saddle isn't touching on the thinline strip under certain strings which makes them not ring out like the rest.Maybe just a little sanding of the bottom of the saddle.Of course this varies with the style of piezo pickup you have in that model.
Thumb
Posted 2003-02-02 12:56 PM (#213276 - in reply to #213266)
On the thinline pickup the piezos & saddle are a integral unit, so you can't just sand the bottom of the saddle. The most likely culprit is that the bottom of the saddle slot is uneven. Re-routing it pefectly flat is pretty easy if you have the tools and skill.
