Ground-to-shell XLR cable
Posted 2003-04-25 4:20 AM (#209702)
Subject: Ground-to-shell XLR cable
Does anyone know WHY after all these years the Adamas needs a special XLR cable? There has been some discussion of this lately, and I have seen this question a few times. I actually had the same problem/frustration when I got my first Adamas trying to figure this out.
It would seem everything from a switched XLR jack to a circuit that sences the phantom power would be better options than a special cable. The whole idea of the dummy 1/4" plug just seems silly to me also.
Posted 2003-04-25 5:04 AM (#209703 - in reply to #209702)
Subject: Re: Ground-to-shell XLR cable
Miles, I'm a little confused here. My SMT works perfectly on phantom power with a standard XLR cable (no ground-link to the shell) and without a dummy plug.
As far as I can tell the reason for the dummy plug is a) if you have a mixer which doesn't supply phantom or b)you want to go from the XLR to a jack input.
Jiminos
Posted 2003-04-25 11:45 AM (#209704 - in reply to #209702)
April 2002
hmmmm.... xlr works great on my SMT.... using a peavey 600e head (with phantom pwr). have had no probs. perhaps it is as Paul said.... gotta have phantom.... sans phantom, gotta use the plug.
Posted 2003-04-25 12:17 PM (#209705 - in reply to #209702)
I was just referring to the recent posts and also my own experience. Maybe they have changed something on the newer models. That's kindof why I posted this question... to clarify. Some of the earlier posts on the subject left me totally confused.
Picker
Posted 2003-04-25 3:47 PM (#209706 - in reply to #209702)
April 2003
Interesting. My SMT does NOT give any signal on the XLR, even with phantom power. Only if I plug in the 6mm jack, or of I use that special cable (I assume - didn't try it yet). Yes I agree, it's a little weird.
Picker
Posted 2003-04-26 10:15 AM (#209707 - in reply to #209702)
April 2003
Hmmm... I opened my XLR cable this morning and soldered the #1 pin to the shell, as mentioned elsewhere, but... NOPE! Just some hard banging and cracks when I play. Until I plugged in the 6 mm jack, and then it worked fine again. So - what can be the problem?
