Adamas Low Impedence outputs
sirdaniel
Posted 2003-05-20 3:27 PM (#208822)
Subject: Adamas Low Impedence outputs
What's Matt talking about when he says to put a jack into the hi input when using the lo?
Also, what's the scoop on stereo preamps?
Posted 2003-05-20 5:00 PM (#208823 - in reply to #208822)
Subject: Re: Adamas Low Impedence outputs
Dan
to use the low impedance jack you need to put a Dummy plug in the 1/4 hole. So you need something plugged in there to make the battery work. or you can call service and buy on of their specially wired cables
sirdaniel
Posted 2003-05-21 3:36 PM (#208824 - in reply to #208822)
thats bizarre, I was at rehearsal a week ago and used the XLR out and it worked fine...
Posted 2003-05-21 4:41 PM (#208825 - in reply to #208822)
I would appear that the Optima doesn't need a dummy plug or special cable, mine certainly doesn't, the Op50 seems to.
