I have some questions
Neo
Posted 2003-05-29 2:23 PM (#208514)
Subject: I have some questions
April 2003
Hello,
I'm just start to practice guitar. So, I have some question for you.
1.How often should I change strings?
2.What is a neck reset?
3.How can I protect my guitar from changes in humidity and temperature?
4. Can I buy and change saddle by my self? "Ovation celebrity model"
Thank you
:eek: :rolleyes:
Posted 2003-05-29 3:02 PM (#208515 - in reply to #208514)
Subject: Re: I have some questions
Hi Neo,
I'm no expert but my advice is the following:
When strings start to sound dead or show signs of wear. Also older strings may be harder to keep tuned properly. There is no right time like x weeks or months. Just go by sound and feel.
If the neck is straight but the angle to the guitar body is not correct it will be difficult or impossible to get the saddle height correct for good playing comfort and sound. A good repair shop should be able to reset the neck to make it line up correctly.
Stable temp and humidity is important. Temperature between 70-75 degrees and humiduty around 40-45% is best. If you live in a very dry environment you should use a humidified - either a full room model or one of the small ones that goes into your case. Do a search on this board and you eill find some good discussion on this topic by experts.
On an acoustic only model this is very simple. More difficult on a acoustic/electric one. You can get replacement saddles from the factory. Just curious why you think you need to change your saddle?
Good luck and happy playing,
Posted 2003-05-29 4:59 PM (#208516 - in reply to #208514)
Also, change your strings when your D strings snaps in the middle of the night.
Posted 2003-05-29 5:05 PM (#208517 - in reply to #208514)
. . . and "rubber up" when her G-string snaps in the middle of the night!
Posted 2003-05-29 6:56 PM (#208518 - in reply to #208514)
Oh Lord, here we go again......
TK17
Posted 2003-05-30 12:04 AM (#208519 - in reply to #208514)
LoL
