Ovation internals
biglouis
Posted 2003-05-31 1:57 PM (#208478)
Subject: Ovation internals
I'm new to Ovations and I'm intrigued by what the internal layout looks like.
On the back of my Elite Special is a round plate with a single screw. Can I take this off and look inside? Are they any problems with trying to take this off or any issues I should be aware of before trying this?
TIA for any responses
Louis
Rich
Posted 2003-05-31 3:37 PM (#208479 - in reply to #208478)
Subject: Re: Ovation internals
July 2002
If you ever attempt to adjust the truss rod, you'll have to remove this panel. Be aware that once you remove the screw holding it on, you'll have to slide the panel around a little to remove it. Good luck and have fun! :)
TRboy
Posted 2003-05-31 9:15 PM (#208480 - in reply to #208478)
February 2003
Hey biglouis,
I've got a drywall circle cutter and a 1/2"
drill you can borrow if you need it!!!
Mike :D
biglouis
Posted 2003-06-01 3:57 AM (#208481 - in reply to #208478)
Hey Trboy
The dry wall cutter might work but I could go the whole hog, get my jigsaw out and cut a really large access hole in the back!
TRboy
Posted 2003-06-01 2:41 PM (#208482 - in reply to #208478)
February 2003
YEAH!! JIGSAW!! Now you talkin' - I LOVE the smell of power tools in the morning :D
Seriously ;) you may have already found out that the screw loosens a spring steel "X" on the back of the access circle. Once you get through looking around inside (be carefull when you pull your head out that you don't get your ears caught on the bowl-really smarts) don't tighten the screw to tight or you may distort the cover! (you may have read that in an earlier post)
Mike :cool:
