Speaking of saddles.....
Posted 2003-12-10 4:28 PM (#199614)
Subject: Speaking of saddles.....
Ref: non-electic Balladeer circa 1971.
Brief history....I had the neck adjusted within the first 4 months. Over the years I have removed all the shims and have taken material off the saddle itself. Currently there is about the width of a nickel from the low E string to the bridge. I have not had to make any adjustments in the saddle in over 15 years. The action is very playable.
Now.....until I found this board I did not know that the lack of string angle at the saddle can affect the sound quality. Is a trip to a good guitar doctor for a neck adjustment a solution for this?
I love the way it sounds now. In searching for a second guitar I have not found a better sounding instrument in it's class. Will a neck adjustment make it sound (dare I ask)...even better????
Brad
Roundback
Posted 2003-12-10 5:11 PM (#199615 - in reply to #199614)
Subject: Re: Speaking of saddles.....
From your description, sounds like the guitar will be needing a neck set. If you have a high action, and a low saddle, thats a pretty good indication.
Mike
Old Applause Owner
Posted 2003-12-10 5:41 PM (#199616 - in reply to #199614)
July 2003
Brad, if you like it the way it is right now, both the action and the sound, I wouldn't touch it. Sounds like "the planets are aligned"! :)
Roger
1976 Applause AA14-4 6-String
2001 Adamas 1598-MERB Melissa Etheridge 12-String
2003 Celebrity CC01 Spruce Top 6-String
Posted 2003-12-10 6:15 PM (#199617 - in reply to #199614)
Mike,
The action is fine.
Roger,
Yep, I thought that too. If it's not broken, don't fix it.
Thanks guys.
Brad
