Is having no shims ok?
-Brian-
Posted 2004-05-29 1:20 PM (#186402)
Subject: Is having no shims ok?
I was reading over my manual, and it said 1-3 shims were put under the saddle to achieve standard action. Is it alright to take out all the shims?
CharlieB
Posted 2004-05-29 1:41 PM (#186403 - in reply to #186402)
Subject: Re: Is having no shims ok?
January 2004
Yes
Posted 2004-05-29 6:09 PM (#186404 - in reply to #186402)
as long as the strings do not buzz on the frets or bridge.
Posted 2004-05-29 6:28 PM (#186405 - in reply to #186402)
and as long as there is sufficient saddle hieght above the bridge to achieve a good string break angle, or volume, sustain & tone can suffer.
Posted 2004-05-29 6:38 PM (#186406 - in reply to #186402)
I had just adjusted a friend's Yamama. It had some years and shifting. Took the truss rod to the "If this snaps I'll have to buy him an Ovation" point and then shaved the saddle about 3/64". A little oil and elbow grease and it's sweet now.
Its not an O mind you but it has a sweet voice.
Posted 2004-05-29 6:53 PM (#186407 - in reply to #186402)
what they said./
Duncan J
Posted 2004-05-31 8:07 AM (#186408 - in reply to #186402)
Even if there's no string buzz anywhere on the neck, if there's not enough downward angle of the strings behind the saddle, you'll have intonation problems.
