Q about mic impedance
iconocoustica
Posted 2004-06-08 2:34 PM (#185722)
Subject: Q about mic impedance
July 2003
Hi,
I am interested in getting the Shure PG48 mic for talking between songs when I perform (I am an instrumentalist). It comes with either an XLR cord or a 1/4 inch. It would be easier for me to get the 1/4 inch since I am already using the 2 XLR inputs on my amp. Does anyone know if this creat an inpedance problem? If so, what would be the effect on the sound from the mic? Thanks.
Franklin
CharlieB
Posted 2004-06-08 5:11 PM (#185723 - in reply to #185722)
Subject: Re: Q about mic impedance
January 2004
Get it with the XLR cord, and get one of the adapters that has an impedance matching transformer in it, so you can run it on a 1/4 inch jack. You'll have the best of everything at that point, since you could take any of your XLR equipement and run it high impedance when needed. Those adapters (by Shure, EV, others) are pretty cheap.
iconocoustica
Posted 2004-06-08 8:57 PM (#185724 - in reply to #185722)
July 2003
Yeah, I have one of the adaptors. I was hoping the 1/4 inch mic/cable would work since the adaptor is one more thing to keep up with/lose! I was wondering if anyone knew anything about these Shure mics with the 1/4 inch terminals. Are they naturally impedance mis-matched or would they work OK?
Franklin
CharlieB
Posted 2004-06-08 9:35 PM (#185725 - in reply to #185722)
January 2004
The "adapter" is built into the mic, and you get hiZ out to the amp.
Tellin ya... go loZ out of the mic, and impedance match at the amp input. The XLR cable will lock to the impedance matching adapter, you won't lose it. Just do it dammit!!!!
Now back to my regular self. Thank you.
iconocoustica
Posted 2004-06-09 7:45 AM (#185726 - in reply to #185722)
July 2003
Awright, awright, you talked me into it! :)
Franklin
Stevechapman
Posted 2004-06-09 9:24 AM (#185727 - in reply to #185722)
April 2003
Good Going Franklin!! I was going to suggest the adapter..but someone beat me to it! Hope everything is going well for you and your O!!
One day all the Carolina OFC'ers are going to have to get together for a jam.
sounds like fun doesn't it?? :D
Bob Mintus
Posted 2004-06-09 6:24 PM (#185728 - in reply to #185722)
Franklin - there is a good reason to use the lo-Z outputs wherever possible - noise immunity.
I'm a Electrical Engineer (by degree, I mostly do controls/software). The impedance (Z, or the AC equivalent of resistance R) of a circuit, determines how much that circuit "loads down" a signal source it sees. Low impedance circuits don't impede or resist the flow of electrical current much. High impedance circuits, on the other hand, impede or resist current flow a lot.
So lo-Z circuits require a signal source that can deliver a large amount of current. Noise sources do not meet this requirement. As a result, most of the signal power the lo-Z circuit sees is the sound of your voice - so you get a better signal to noise ratio - i.e., cleaner sound.
Why use the converter to go into your amp? For most of the run, the signal is lo-Z and less susceptible to noise. The hi-Z portion of the run is small, so you'll get less noise pickup than if the whole run were hi-Z. A long mike cord acts like an antenna, and the longer the cord, the more susceptible you are. Additionally, the hi-Z circuits have problems supplying enough signal when you go to longer distances.
Down the road, when you're playing out and plugging into that expensive PA or buy that really expensive amp, you can get rid of the impedance transformer.
I hope that's not too technical... If you haven't noticed, all the expensive Ovation guitars, as well as the Adamas models, all include a lo-Z output. That's why.
High impedance circuits do have their uses, however (voltage measurements are the first example that comes to mind), when you don't want to affect a circuit. The highest impedance you ever get is when you're disconnected.
- Bob
iconocoustica
Posted 2004-06-10 7:59 AM (#185729 - in reply to #185722)
July 2003
Thanks for the great explantion, Bob. I did decide to go with the XLR mic and use my converter at the amp.
Franklin
P.S. Steve, I wonder how many of the OFC'ers are Carolinians?
Stevechapman
Posted 2004-06-10 9:08 AM (#185730 - in reply to #185722)
April 2003
Franklin,
Good Question. TR Boy is in SC and their may be at least 5 or 6 of us in NC. maybe we'll catch some responses here or start a new Thread looking for OFC'ers in the Carolina's.
Slap
Posted 2004-06-10 12:34 PM (#185731 - in reply to #185722)
Steve
what part of carolina? I'm in Northern Virginia.
Stevechapman
Posted 2004-06-10 12:54 PM (#185732 - in reply to #185722)
April 2003
Sam,
I'm in Fayetteville,NC and Franklin I believe is in Winston-Salem, I've seen 2 or 3 posts from Charlotte, NC members and TRboy lives in SC. Not sure if there are any others out there.
Slap
Posted 2004-06-10 1:15 PM (#185733 - in reply to #185722)
Steve
I'm in Warrenton, VA. My mother lives at Rocky Mount VA....not far from Winstom Salem....
Fayetteville....Fort Bragg area right?
I used to fly into Seymore Johnson several times when it was still open.
I'm open to a central Carolina area to get together
